English
Problem: AI files exported from ArcView GIS 3.x do not open properly in Adobe Illustrator
Adobe Illustrator (*.ai) files exported from ArcView GIS 3.3 do not open properly in Adobe Illustrator, such as Adobe Illustrator CS3.
Cause
The Adobe Illustrator format (*.ai) from ArcView GIS 3.3 is not compatible with newer versions of Adobe Illustrator.
Solution or Workaround
Export the layout or view from ArcGIS GIS 3.x as 'PostScript (New)', which opens correctly in Adobe Illustrator CS3.
