English
How To: Alter a logical network table's pageblob attribute's LOB segment from NOCACHE to CACHE
Summary
Instructions provided describe how to alter a logical network table's pageblob attribute's LOB segment from NOCACHE to CACHE. If a logical network table containing a pageblob attribute is created without specifying the storage options for the LOB segment, Oracle's default setting is NOCACHE, meaning LOB values are not brought into the buffer cache.
To improve performance it is recommended the LOB segment that represents the pageblob attribute is CACHED, reducing physical I/O operations.
Procedure
To change the default NOCACHE setting for LOB segments to CACHE, use the ALTER TABLE command in SQL*Plus.
  1. Identify all the logical network tables where the pageblob attribute's LOB segment is set to NOCACHE.
    Code:
    SQL> SELECT table_name, cache
    2 FROM user_lobs
    3 WHERE column_name = 'PAGEBLOB'
    4 AND cache = 'NO';
    TABLE_NAME CACHE
    N_3_JTOPO NO
  2. Alter the table and verify that the LOB segment is now cached.
    Code:
    SQL> ALTER TABLE n_3_jtopo
    2 MODIFY LOB (pageblob)(CACHE);
    Table altered.
    2 FROM user_lobs
    4 AND table_name = 'N_3_JTOPO';
    TABLE_NAME CACHE
    N_3_JTOPO YES
    See Oracle's documentation for additional information.
Related Information
