BUG
Incorrect variable assignment in st_type_export.validate_spref prevents user schemas from being imported correctly without errors
When using Oracle's Data Pump Import utility with the option to import an entire schema, which includes tables with st_geometry attributes and spatial indexes, the Oracle error ORA-20091 may occur.
Cause
Using the Oracle Data Pump Import utility or the original import utility, the Oracle error ORA-20091 may occur.
The reason of the cause is an invalid variable assignment within st_type_export.validate_spref.
This is a specific problem introduced in ArcGIS 9.2 Service Pack 5.
Workaround
Currently there is no workaround to the problem.
    Article ID:000009904
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
