ERROR
Multipart Polyines are not allowed for network features
Error Message
When using XML Import or the Extract Data and Create Replica commands on the Distributed Geodatabase toolbar, if the source features are geometric network features, the operation may fail and displays the following error message:
"Multipart polylines are not allowed for network features".
Cause
The operation is failing because of the presence of multipart polylines within the source geometric network feature classes. These features are invalid within the geometric network; therefore, they are flagged as build errors during network creation.
For more information, refer to the following link: Identifying Geometric Network Build Errors.
Solution or Workaround
Correct the geometry of the features in the source network feature class using the steps outlined in the Desktop Help topic "Repairing geometric network connectivity" and follow the directions under the section titled: "Rebuilding features with multipart geometry".
The Desktop Help topic can be found at the following link: Repairing geometric network connectivity.
    Article ID:000009898
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
