ERROR
Business Analyst installation: There are no map services available
Error Message
During the Business Analyst Web Application Post Installation, the following error message displays:
"There are no map services available."
Cause
ArcGIS Server Manager is not running or the permissions in the .NET Framework are not set correctly.
Solution or Workaround
  • Using the operating system's Services panel, make sure that the ArcGIS Server Manager (SOM) service is started.
  • Check the .NET Framework permissions. Set the permissions, as described in step 8 of the Business Analyst Server Installation Guide.
Article ID:000009879
Software:
  • ArcGIS Business Analyst Enterprise
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
