ERROR
Failed: Can't get security info for $:\BAServerRepository. Check your access rights
Error Message
The following error message displays during file-based repository creation for Business Analyst (BA) Server:
"Failed: Can't get security info for $:\BAServerRepository. Check your access rights."
Cause
This error occurs if the BA Server repository is being created with a FAT32 file system type on a Windows 2003 Server operating system. FAT32 uses a different security model than the NTFS file system.
Solution or Workaround
  • Change the BA Server repository location to an NTFS file system.
Article ID:000009877
Software:
  • ArcGIS Business Analyst Enterprise
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
