ERROR
Business Analyst Server Map is not started
Error Message
When launching Analysis Center for Business Analyst Server, the following error message displays:
"Business Analyst Server Map is not started."
Cause
All instances of the DefaultMap map service are being used.
Solution or Workaround
  • Using 'ArcGIS Server - Map Service Properties' in ArcCatalog, increase the maximum number of non-pooled instances for the DefaultMap map service.
Article ID:000009874
Software:
  • ArcGIS Business Analyst Enterprise
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
