ERROR
RegCat run-time error -2147319779 (8002901d) Automation error Library not registered
Error Message
While installing or uninstalling ArcGIS Desktop, the following error is received:
"RegCat
Run-time error '-2147319779 (8002901d)': Automation error
Library not registered."
Or when launching ArcMap, the following error is received:
"Startup
Automation Error
The specified module could not be found."
Cause
This error occurs when the Window Script engine is missing from the computer.
Solution or Workaround
Install the Windows Script engine. The link to the Windows Script engine download is listed below in Related Information.
    Article ID:000009855
    Software:
    • ArcMap 9 x
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
