PROBLEM
Vector shapes are distorted or snapped to a grid when exported to PDF
Vector shapes are distorted or snapped to a grid when exported to PDF.
For example, this is how the feature looks in ArcMap Layout, zoomed in at approximately 3000%:
[O-Image] Feature as viewed in ArcMap Layout zoomed in at 3200%
This is how the same feature looks in the exported 300dpi PDF at 3200%:
[O-Image] Feature displayed in PDF at 3200%
Cause
This most likely occurs when viewing the PDF at a high zoom percentage. For example, 1000% or higher. This happens with PDFs generated from any application.
Even when exporting a pure vector map to PDF, do not expect the vectors to maintain perfect geometry when zooming in to a percentage much greater than the output resolution.
Solution or Workaround
Increase the export resolution and do not zoom in to such high resolutions on the PDF display.
    Article ID:000009838
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
