English
Problem: Creating a multiversion view fails with 'Table is not multiversion...'
Creating a multiversion view returns the following error:
"Error: Table is not multiversion, but must be for this operation (-178).".
Code:
C:\>sdetable -o create_mv_view -T parcels_view -t parcels -i 5151 -u sde -p sde
ArcSDE 9.2 for Oracle10g Build 449 Wed Jan 16 12:20:02 2008
Attribute Administration Utility
Error: Unable to create MV view parcels_view for table parcels.
Cause
To create a multiversion view requires the table or layer to first be registered as versioned. If the table or layer is not registered as versioned, one will encounter the above error.
Solution or Workaround
Multiversion views require the underlying table or layer to first be registered as versioned.
One can register a table or layer as versioned in ArcGIS by using ArcCatalog. Select the data source, right-click to open the context menu, and select the 'Register As Versioned...' command.
