BUG
Applying a spatial filter on a view created with sdetable in Oracle returns "ORA-00918: column ambiguously defined"
Applying a spatial filter on a view created with sdetable returns the following error:
"ORA-00918: column ambiguously defined".
This may happen when a view is created with sdetable -o create_view when two tables are joined in the view's definition.
Code:
sdetable -o create_view -T land_view -t parcels,land -c parcels.objectid,parc
els.shape,parcels.parid,land.taxyr,land.ltype,land.parid -w "parcels.parid=land.parid(+)"
When the view is added to ArcMap and the session zooms into an area (performing a spatial query), an underlying Oracle error is encountered.
Cause
Internally, ArcSDE generates a query with an invalid attribute that is not fully qualified to reference one of the two tables defined in the view.
Workaround
Currently there is no workaround that addresses this issue.
    Article ID:000009824
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
