English
How To: Install the ArcGIS 9.2 Getting Started with ArcGIS tutorial data
Summary
Instructions provided describe how to install the Getting Started with ArcGIS tutorial data for ArcGIS 9.2.
Procedure
The tutorial data and PDF are available at this tutorial data download link:
Getting Started Tutorial Data Download
  1. Click the tutorial data download link.
  2. Save the Getting_Started.zip file to the computer (the file is 9.39MB).
  3. Unzip the tutorial data to C:\arcgis\ArcTutor (the default tutorial install location) or to another location, in which there is write access.
  4. The tutorial instructions are found in the Getting_Started_With_ArcGIS.pdf file, which is installed in the same folder as the Getting Started tutorial data.
