English
Bug: Error reading the batch file
Opening a ReViewer Batch Job (.rbj) file in either ReViewer Batch Job Manger or ReViewer Batch Validate for Production Line Tool Set (PLTS) for ArcGIS 9.2 Foundation Service Pack 3 returns the following error:
"There was an error reading the batch file:
COM Exception reading batch file 'C:\temp\MyBatchFile.rbj'
Project Info: , Source: Reviewer.RevBatchJob.1, Description: Unknown Error, Stack Trace: at
ESRI.ArcGIS.esriSystem.XMLSerializerClass.ReadObject(IXMLReader pReader, IPropertySet environment, IXMLFlags flags)
at ESRI.PLTS.Revewer.Desktop.RevBatchJobUtil.Open(String filename), Caller: WriteInnerToOuter called from: Open, Type:[COMException]"
Cause
At PLTS for ArcGIS 9.2 Foundation Service Pack 3, the Polyline/Polygon Sliver or Gaps check was modified to accept polygon features only; therefore, it has been renamed Polygon Overlap/Gap or Sliver check. Since the Polyline/Polygon Sliver or Gaps check is no longer a valid check, any reference to it in an existing Batch Job File cannot be resolved; therefore, the check cannot be loaded into the ReViewer Batch Job Manager or ReViewer Batch Validation.
Workaround
This issue has been addressed in PLTS for ArcGIS 9.2 Foundation Service Pack 4.
    Related Information
