HOW TO
Note: ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed.
Instructions provided describe how to set the TCPKEEPALIVE = TRUE for ArcSDE. Setting this parameter removes any detached gsrvr processes running on the server.
Note: TCPKEEPALIVE does not clean up entries in the SDE.PROCESS_INFORMATION table.
Get help from ArcGIS experts
Download the Esri Support App
