English
Error: Internal error 2753.DoesFileExist.exe. Installation ended prematurely because of an error
Error Message
When installing ArcGIS ArcInfo Workstation, the following error displays:
"Internal Error 2753. DoesFileExist.exe'. Installation ended prematurely because of an error."
Cause
The directory, where ArcGIS ArcInfo Workstation is installed, contains files from a previous release.
Solution or Workaround
  1. Cancel out of the current ArcInfo Workstation install.
  2. Make sure the directory that the location where ArcGIS ArcInfo Workstation is going to be installed does not contain any files from a previous ArcInfo Workstation release.
  3. Install ArcInfo Workstation.
Related Information
