ERROR
PrjData.dll not found. Projection and datum transforms may not operate correctly
Error Message
Starting ArcPad 7.1 may result in the following ArcPad warning message:
"C:\Program Files\ArcPad 7.0\System\PrjData.dll not found.
Projection and datum transforms may not operate correctly".
[O-Image]
Cause
The uninstallation process does not remove 7.0.1 version of ArcPadPrefs.apx from My Documents on Desktop PC installations. Thus, ArcPad still searches for System folder in C:\Program Files\ArcPad 7.0\System path.
Solution or Workaround
There are two possible workarounds that resolve this error:
  • Modify the System Files Path in the ArcPad Options > Paths dialog box to display C:\Program Files\ArcPad 7.1\System (Tools > Options > Paths > System Files Path).
    [O-Image]
  • Delete the ArcPadPrefs.apx in My Documents before opening ArcPad 7.1 for the first time.
Article ID:000009785
Software:
  • ArcPad Prev
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
