Answer
Unified Modeling Language (UML) is used in Visio and Rational Rose to create geodatabase design diagrams that can be exported to XML with an XMI Exporter, so that the schema can be imported into a geodatabase. The supported versions for UML are 1.3 and 1.4. The supported versions of the XMI Exporter are 1.0 and 1.1.
