BUG
ArcGIS reconcile crashes application when a relationship class has several hundred modifications in Oracle
Reconcile crashes the application when a large number of modifications have been performed in the origin or destination relationship class for the version being reconciled.
Cause
Internally during the reconcile process the geodatabase creates a keyset table used to store the origin or destination primary/foreign key values for quickly traversing the attributed relationship class. If the number of modifications in the origin or destination attributed relationship class for the version being reconciled exceeds 200 objects, uninitialized memory is referenced and the application crashes.
Workaround
Apply the ArcGIS 9.2 SP4 Reconcile patch available on ESRI Support Center.
Patches and Service Packs - ESRI Support
    Article ID:000009778
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
