English
Problem: Flex Builder reports a problem about the AWXFramework
When using ArcWeb Explorer Flex API, Flex Builder reports the following problem:
ā€¯Could not resolve <awx:AWXFramework> to a component implementation".
Cause
The wrong class is being used.
Solution or Workaround
The correct class to use is Framework:
Code:
<awx:Framework apiKey="[Your API Key here]"/>
