English
FAQ: Are ArcWeb Explorer Flex API Extensions free?
Question
Answer
There is no charge to use ArcWeb Explorer Flex API Extensions to connect to your own ArcGIS or ArcIMS services. However, it is necessary to register your site and use an API Key for authentication purposes. There is a charge if you connect to ArcWeb Services using ArcWeb Explorer Flex API Extensions.
Related Information
