BUG
Unable to create a partitioned local st_spatial_index in parallel in Oracle
Creating a partitioned local st_spatial_index in parallel fails with the following Oracle error:
"ORA-12801: error signaled in parallel query server P000"
and Oracle error:
"ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine".
The following is an example on how to create a partitioned local st_spatial_index index with the parallel argument set to a value of 2:
Code:
CREATE INDEX st_shape_index
ON parcels (shape)
INDEXTYPE IS sde.st_spatial_index
LOCAL (PARTITION quarter1 PARAMETERS('st_srid=1 st_grids=280 TABLESPACE q1_idx'),
PARTITION quarter2 PARAMETERS('st_srid=1 st_grids=280 TABLESPACE q2_idx'),
PARTITION quarter3 PARAMETERS('st_srid=1 st_grids=280 TABLESPACE q3_idx'),
PARTITION quarter4 PARAMETERS('st_srid=1 st_grids=280 TABLESPACE q4_idx'),
PARTITION qunknown PARAMETERS('st_srid=1 st_grids=280 TABLESPACE qunknown_idx'))
PARALLEL 2
Cause
An internal error in the sde.spx_util package (a unique constraint violation), during the creation of the partitioned local st_spatial_index, prevents the indexes from being created in parallel.
Workaround
Do not create the partitioned local st_spatial_index in parallel. Remove the parallel clause from the CREATE INDEX statement.
    Article ID:000009714
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
