HOW TO
Clean up detached records in the SDE repository tables using ArcCatalog
Last Published: April 30, 2021
Summary
This article pertains to ArcGIS versions 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed.
If ArcCatalog closes prematurely while deleting or creating a feature class, it can leave detached entries in the SDE repository tables.
When the business table is deleted in ArcCatalog, the feature class fails to appear in the table of contents.
Procedure
To clean up entries in the SDE repository tables, perform the steps below using the following example of a deleted feature class: joe.roads.
  1. In Query Analyzer (SQL Server) or Sqlplus (Oracle), create a table by the name of 'roads' and 'joe' as the name of the user. The table name should be the exact name as the deleted table and this should be created by the original data owner.
  2. Make a spatial database connection as user 'joe' in ArcCatalog.
  3. The roads feature class now appears in the table of contents in ArcCatalog. Right-click it and select 'delete'.
Article ID:000009712
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
