English
Problem: ArcInfo WorkStation 9.2 Patch for the Sun Solaris X11 causes ArcPlot to crash
** This issue is resolved in ArcGIS 9.3. **
Sun Solaris X11 Security Patch ID 119059-27 for Solaris 10 and Sun Solaris X11 Security Patch ID 112785-62 for Solaris 9 cause the following problem with ArcInfo Workstation:
ArcPlot crashes.
Higher versions of the Sun patches listed above may also cause these failures.
Cause
The above Solaris patches modify the behavior of the XCreateImage system call, which results in failures in ArcInfo Workstation products.
Solution or Workaround
To resolve this problem, download the WorkStation patch from: ArcGIS 9.2 Patch for the Sun Solaris X11 Security issue.
