ERROR
Error in script FeatureClassToShapefile. Failed to execute
Error Message
When running any of the Geoprocessing Tools in ArcCatalog, an error message similar to the following may be encountered:
"...Error in script FeatureClassToShapefile.
Error in executing: cmd.exe /C C:\PROGRA~1\ArcGIS\ARCTOO~1\Scripts\FEATUR~1.PY "'Database Connections\Connection to test.sde\tcgis.ADMIN.cemeteries'" "C:\shapes" "C:\shapes"
Failed to execute (FeatureClassToShapefile_1).
End Time: Wed Oct 10 13:40:30 2007 (Elapsed Time: 1.00 seconds)"
Cause
Python 2.1 does not correlate to ArcGIS 9.2. If both Python 2.1 and Python 2.4 are being used with ArcGIS Desktop 9.2, an error message indicating that the Geoprocessing Tool failed to execute is encountered.
Solution or Workaround
Uninstall the Python 2.1 version, since it does not correlate to ArcGIS Desktop 9.2.
Python 2.4 is installed with the ArcGIS Desktop 9.2 installation.
    Article ID:000009691
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
