When starting the ArcGIS Server on a Sun Microsystems machine, the Xvfb virtual display server does not start. Several ports are attempted, such as 600-619.
When executing manually using the init_xvfb script, the following messages occur:
"Could not find encodings.dir in /usr/openwin/lib/X11/fonts/encodings. Check installation."
"Could not find ttmaps.dir in /usr/openwin/lib/X11/fonts/TrueType/ttmap. Check installation."
Cause
Not all packages of the X Windows System are installed.
Solution or Workaround
Ensure that all packages of the X Windows System are installed.
The two missing files are found in the following SUN packages:
SUNWxwfnt
SUNWgttf
SUNW5ttf
SUNWi13rf
SUNWi15rf
SUNWi7rf
SUNWi9rf
SUNWinttf
SUNWcttf
SUNW1251f
SUNWarrf
SUNWjxcft
SUNWtxfnt
SUNWi4rf
SUNWi8rf
SUNWkttf
