PROBLEM
Custom ArcPad applications after upgrading to ArcPad 7x environment may crash the ArcPad application when launched. This could be a result of the ArcPad XML format change which occurred with ArcPad Application Builder 7.0 and later releases.
All of ArcPad's customization files are stored in ArcPad XML format.
The ArcPad XML format is designed as a protocol for automation and customization of ArcPad. It is based on the XML 1.0 specification and uses the same syntax as ArcXML wherever possible (especially for symbology). ArcPad XML files can be ANSI, UTF-8, Unicode, or Unicode Big Endian encoded.
Although ArcPad and ArcPad Studio take care of writing the ArcPad XML code to the customization files, some developers may find it useful to edit the customization files directly, either manually by way of a text or XML editor, or programmatically within a script.
Get help from ArcGIS experts
Download the Esri Support App
