English
Problem: Unable to connect to Bluetooth GPS within ArcPad
User unable to connect to Bluetooth GPS device within ArcPad, but GPS functionality works correctly when run in built-in GPS application installed on device.
Cause
This is caused by the built-in GPS application running on the device when the user attempts to turn on GPS functionality within ArcPad by way of GPS drop-down menu.
Solution or Workaround
Close all built-in GPS programs on the device; then restart ArcPad and connect to Bluetooth GPS via GPS Preferences option from GPS drop-down menu.
