PROBLEM
Coded domain automatically being assigned to date field
In features classes that have a text field that has a coded domain assigned to it next to a date field, the date field is automatically being assigned that same domain.
Cause
This is a known issue.
Solution or Workaround
Remove the domain from the field.
  1. Open ArcToolbox.
  2. Open the Data Management Tools.
  3. Open the Domains toolset.
  4. Double click the 'Remove Domain from Field' tool.
  5. Insert all pertinent information and click Ok.
Article ID:000009635
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
