English
Error: The tool is not licensed
Error Message
While attempting to create a globe cache in ArcCatalog for an ArcGIS Server globe service, the following error message displays:
"The tool is not licensed".
Cause
To create a globe cache successfully, the 3D Analyst extension is required for ArcGIS Desktop. The extension must be licensed, and also enabled in ArcCatalog.
Solution or Workaround
If there is no 3D Analyst extension available, check with the License Manager administrator to make sure the 3D Analyst extension is licensed.
  1. In ArcCatalog navigate to Tools > Extensions and ensure that 3D Analyst is checked.
    Re-run the globe cache tool.
Related Information
