ERROR
Error 1904. Module C:\Program Files\ArcGIS\bin\SceneGraph.dll failed to register. HRESULT -2147024769. Contact your support personnel
Error Message
During the installation of ArcGIS Server, the following error message appears:
"Error 1904. Module C:\Program Files\ArcGIS\bin\SceneGraph.dll failed to register. HRESULT -2147024769. Contact your support personnel."
Cause
The SceneGraph.dll failed to register during the installation.
Solution or Workaround
The .dll needs to be registered with Windows after the installation completes.
  1. When prompted with the error during the installation, click 'Ignore' and complete the installation.
  2. After the installation completes, go to Start > Run.
  3. At the Run command, type the following:
    regsvr32 "<arcgis_install_location>\Bin\scenegraph.dll"
    For example:
    Code:
    regsvr32 "C:\Program Files\ArcGIS\bin\scenegraph.dll"
    This problem can also be resolved by applying the most recent ESRI Service Pack found in the Related Information below.
Article ID:000009610
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
