English
Error: FDO error: -2147024890 [featureclass name]
Error Message
Geodatabases may fail to replicate in two-way replication from an ArcGIS Server Geodata service prompting the following error:
"FDO error: -2147024890[featureclass name]"
Cause
A relationship class has the same name as a featureclass inside the geodatabase, which is being replicated.
Solution or Workaround
Change either the relationship class name or the featureclass so that they are not the same.
