ERROR
Error parsing control: A relative URI cannot be created because the'uriString' parameters represents an absolute URI
Error Message
When viewing the Web Mapping Application template in Visual Studio 2005 design time, the TitleMenu control displays the following error message:
[O-Image] Visual Studio Error
Cause
Installing the Security Update for the Microsoft .NET Framework Version 2.0 (KB928365) results in changes to the TitleMenu control in the Web Mapping Application.
Solution or Workaround
  1. Locate the TitleMenu control in the Properties dialog box.
    [O-Image] TitleMenu
  2. For the DataSourceId property, delete the value of 'SitemapDataSource1'.
  3. Find the Items property and open the Menu Item Editor. Click the 'Add Item' button.
    [O-Image] AddItem
  4. Add three new items with the following properties.
    Item 1:
    NavigateURL = http://www.esri.com
    SeparatorImage = ~/images/separator.gif
    ToolTip = ESRI
    Text = ESRI
    Item 2:
    NavigateURL = http://support.esri.com
    ToolTip = ESRI Support Center
    Text = ESRI Support Center
    Item 3:
    NavigateURL = Help/Default.htm
    ToolTip = Help
    Text = Help
    After adding the three items, the Menu Item Editor dialog box should look like the following image:
    [O-Image] Menu Editor
  5. Click OK to close the Menu Item Editor. The TitleMenu control should now appear like the following image in the Visual Studio Design view:
    [O-Image] Design Time
  6. Run the application and verify that each link in the menu works correctly.
    [O-Image] RunTime
Article ID:000009587
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
