English
Error: DBMS table not found [ORA- 00942 : table or view does not exist]
Error Message
When creating a new ST_Geometry layer in Oracle, the following error message displays:
"DBMS table not found [ORA-00942: table or view does not exist]"
An error in the ArcSDE error log displays the following error message:
"S_enable_spatial_type_column::Error adding column(955)"
Cause
One cause of the problem is the ArcSDE DBTUNE parameter st_geom_lob_storage specifically defines a LOB segment name. Oracle's LOB segment name must be unique per schema. Therefore, if the DBTUNE st_geom_lob_storage parameter is not updated each time to store the LOB segment using a unique name, the second attempt to create a new ST_Geometry layer fails and the following error message displays:
For example, the following st_geom_lob_storage parameter value causes the error to occur, because each time the Oracle LOB segment is created it attempts to name the LOB segment 'st_lob_segment'.
STORE AS st_lob_segment (ENABLE STORAGE IN ROW CHUNK 8K RETENTION CACHE)
Solution or Workaround
To avoid the error, do not set a LOB segment name in the storage string for the st_geom_lob_storage parameter.
If the name is not specified, Oracle internally generates a unique name.
To update the ArcSDE DBTUNE parameters use the sdedbtune command.
See the ArcGIS Documentation Library link in Related Information for additional information on the sdedbtune command.
Below is an example of a valid st_geom_lob_storage storage clause:
STORE AS (ENABLE STORAGE IN ROW CHUNK 8K RETENTION CACHE)
    Related Information
