PROBLEM
Section 4-3 of the GPT 3.1 Installation Guide involves configuring Tomcat for Java Naming and Directory Interface (JNDI), and references sample configuration files, which must be copied to the Tomcat/conf/Catalina/localhost directory. These files may be missing from the GPT 3.1 CD.
Since releasing GPT 3.1, the method in which JNDI was configured in Tomcat for use by the GPT has changed. GPT 3.1 was released with files supporting the 'old method' of JNDI definition, whereas the installation guide now references the 'new method'.
Because of this change, users may be missing the sample JNDI configuration files mentioned in section 4-3 of the GPT 3.1 Installation Guide. A log-in is required to access this guide.
Get help from ArcGIS experts
Download the Esri Support App
