PROBLEM
When running the script, Spline with Barriers, a message is returned indicating there was a failure to execute and that Java is not installed. An example of the error returned is below.
This tool requires the Java Runtime Environment Version 5.0, or higher, to be installed.
Get help from ArcGIS experts
Download the Esri Support App
