PROBLEM
SeShape.Intersect could return unexpected geometries when two shapes are too close to each other
SeShape.Intersect could return unexpected geometries when two shapes have any vertices that are too close to each other.
Cause
This problem can occur when the distance between shapes is too small for ArcSDE to intercept correctly with each shape's current resolution.
Solution or Workaround
This is a known limitation for ArcSDE 9.1. For ArcSDE 9.2 and higher, setting the environment variable 'SGMAXRESOVERLAY' to 1 fixes this problem. However, this workaround only works for Java Runtime Environment (JRE) 1.5 or higher.
If this environment variable is set, ArcSDE APIs increase the shape's resolution before certain types of processing, such as intersection, and decrease it afterwards.
It is not recommended to set the environment variable 'SGMAXRESOVERLAY' permanently. Doing so causes the results to change slightly from the existing code, as well as, increases the cost of overlay.
    Article ID:000009555
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
