Frequently asked question
Why can I no longer use a space or underscore in a check-out name?
Answer
In ArcGIS 9.2, replica names, referred to as check-out names prior to ArcGIS 9.2, are validated to ensure they do not contain DBMS specific invalid characters or reserved words. This is necessary because internally the replica name is used to create system tables. This validation applies to names for all replica types: two-way/one-way replicas and check-out/check-in replicas. Each DBMS has its own list of invalid characters and reserved words. The replica name must be valid for the database that is being used. Replica name validation is done with IfieldChecker::ValidateTableName. See the link in the Related Information below for additional documentation.
Existing check-outs created with previous versions of ArcGIS still work when checked in. This validation occurs for all check-outs created using ArcGIS 9.2.
Article ID:000009540
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
