BUG
Cartographic representations disappear when printed or exported
Last Published: February 13, 2024
This article applies to retired ArcMap versions. Later versions of ArcGIS Desktop may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Cartographic representations disappear when printed or exported.
Cause
The data frame that contains the cartographic representations is drawn completely outside the maximum printable area of both the default printer and selected default media installed on the computer.
Workaround
Use the procedure in the Esri Knowledge Base document linked in the Related Information section below.
    Article ID:000009524
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
