English
Error: Invalid CD or directory chosen
Error Message
When updating the ArcLogistics Route 3.0 street datasets using the ESRI provided quarterly Street Update DVDs, the following error may occur:
"Invalid CD or directory chosen"
Cause
The existing ArcLogistics Route street datasets are not in the same location last edited by way of ArcLogistics Route Street Administrator.
Solution or Workaround
The ArcLogistics Route application retains the existing ArcLogistics Route street dataset location last accessed by the Street Administrator utility.
  1. If the above ArcLogistics Route error is received, select OK and browse to the location of the existing street dataset.
  2. If the error message displays after pointing to the correct location of the existing street dataset, re-install the ArcLogistics Route 3.0 Street Data ExtractWizard Patch.
