PROBLEM
After deploying the ArcIMS WFS Connector file, wfsconnector.war, in WebLogic Server 9.2 as described in the ArcIMS Installation Guide under Step 4, the following error message displays after logging into the WFS Connector Administrator configuration page:
Error: "Unable to update properties: Unable to write property file C:/Program Files/bea/weblogic92/samples/domains/wl_server/./servers /examplesServer/tmp/_WL_user/wfsconnector1/tyx1yr/war/WEB-INF/lib/_wl_cls_gen.jar!/WFSEsrimap_prop Error: C:\Program Files\bea\weblogic92\samples\domains\wl_server\.\servers \examplesServer\tmp\_WL_user\wfsconnector1\tyx1yr\war\WEB-INF\lib\_wl_cls_gen.jar!\WFSEsrimap_prop (The system cannot find the path specified)".
WebLogic Server 9.2 does not deploy the .war file correctly with the steps provided.
Deploy the ArcIMS WFS Connector wfsconnector.war file as a folder instead of deploying it directly using the following steps:
It should now be possible to log in to the ArcIMS WFS Connector console and save any property changes as needed.
Get help from ArcGIS experts
Download the Esri Support App
