ERROR
When executing the Analyze command in ArcCatalog 9.2 against an empty feature class stored as ST_Geometry, the following error message is displayed:
"Failed to analyze dataset. DBMS table not found."
If the feature table check box is checked, the analyze command attempts to gather table statistics for a feature table. There is no feature table when spatial attributes are stored using ST_Geometry.
Get help from ArcGIS experts
Download the Esri Support App
