English
Problem: Sun X11 Security Patch causes ArcGIS 9.2 failures on Solaris
Sun Solaris X11 Security Patch ID 119059-27 for Solaris 10 and Sun Solaris X11 Security Patch ID 112785-62 for Solaris 9 cause the following problems:
ArcReader does not open 2D or 3D published maps (.pmf).
ArcGIS Server services do not start.
ArcIMS ArcMap services do not start.
ArcInfo Workstation ArcPlot Text commands are failing when using DISPLAY 9999 and using TrueType fonts or Intellifonts.
Higher versions of the Sun Solaris patches listed above may also cause these failures.
Cause
The above Solaris patches modify the behavior of the XCreateImage system call, which results in failures in the ArcGIS products.
Solution or Workaround
ArcGIS Server, ArcIMS and ArcReader
Click on the link in Related Information below to download ESRI's patch that fixes this problem.
ArcIMS Users
Check the /tmp, /var/tmp, and $AIMSHOME/log directories for extra files that may have been generated by the IMS user after Sun’s X11 patch was installed. Remove .tmp files or log files to free up space if needed.
Related Information
