PROBLEM
UNIX C++ API Help default text size is too small to read
On machines with NVIDIA video cards, the C++ API Help default text size may display too small to read.
Cause
The default Dots Per Inch (DPI) is set too small.
To check the current DPI setting, run:
% xdpyinfo | grep "resolution"
resolution: 69x69 dots per inch
The above output is an example of a low DPI setting.
Solution or Workaround
Override the calculated DPI.
For NVIDIA cards, add the following lines to the 'Device' section of the config file located either in /etc/X11/xorg.conf (Xorg) or /etc/X11/XF86Config (XFree86):
Option "UseEdidDpi" "FALSE"
Option "DPI" "96 x 96"
See the link 'LinuxQuestions.org' in the Related Information section below for a forum string on 'How to Stop DPI from changing on resolution change'.
For additional information about using the DPI to determine how large (in pixels) to draw an object on the display service, click NVIDIA Accelerated Linux Driver Set README and Installation Guide. In your browser menu click Edit > Find (or type CTRL+F). In the Find field, type 'Appendix Y. Dots Per Inch'.
Article ID:000009476
Software:
  • ArcGIS Engine
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
