ERROR
Duplicate key in Shape column
Last Published: April 26, 2020
Error Message
Posting a version to the default version results in the following error message:
Error:
The version could not be posted.
Underlying DBMS error[Microsoft OLE DB Provider for SQL Server: Duplicate key in Shape column.]
Saving edits to the default version results in the following error message:
Error:
Unable to save edits.
Cause
This bug is specific to ArcSDE SQL Server geodatabases in which feature classes have archiving enabled before applying a service pack.
A trigger is created when archiving is enabled for feature classes after a service pack is applied. The naming convention for the trigger is sp_col_ins_<layer_id>. Layer_id is the value in the layer_id column in the sde_layers table for the history layer.
Both "Duplicate key in Shape column" errors are caused by a trigger on the history table for the feature class or classes being edited.
Solution or Workaround
Upgrade to ArcSDE 9.2 Service Pack 4 or later releases, or drop the trigger after the upgrade. The trigger can be dropped with the T-SQL code below.
The code works for single and multiple database models. Ensure that the SQL Server Query Analyzer is pointing to the database with the SDE/DBO schema.
If using a DBO owned ArcSDE schema change the @AdminUser variable below from 'sde' to 'dbo'.
SQL Server 2005:
-- This code drops triggers that are not needed on history tables.
-- Need to run this code from the admin databases ... ex: sde database.
-- SQL Server 2005 specific
declare @dbName			varchar(100)
declare @owner			varchar(100)
declare @SelStmt		varchar(1000)
declare @TrigName		varchar(100)
Declare @AdminUser		varchar(30)
Set @AdminUser		= 'sde'
Set @SelStmt =
	'select distinct database_name into ##sde_0_DatabaseName
	from ' + @AdminUser + '.sde_table_registry tr
	join ' + @AdminUser + '.sde_archives ar
	on tr.registration_id = ar.history_regid'
Exec (@SelStmt)
declare ch cursor
for
	select database_name from ##sde_0_DatabaseName
open ch
Fetch ch into @dbName
while (@@fetch_status=0)
begin
	-- Get a list of the triggers
	set @SelStmt =
	'select tr.owner, st.name into ##sde_1_TriggerName
	from ' + @dbName + '.sys.objects so
	join ' + @AdminUser + '.sde_table_registry tr
	on so.name = tr.table_name
	join ' + @dbName + '.sys.triggers st
	on so.object_id = st.parent_id
	where (st.name like ''sp_col_ins%'')'
	--print @SelStmt
	exec (@SelStmt)
	-----------------  Inner Cursor to drop triggers
	Declare tr cursor
	for
		select * from ##sde_1_TriggerName
	open tr
	Fetch tr into @owner,@TrigName
	Begin
		set @SelStmt = 'USE ' + @dbname +'; DROP TRIGGER ' + @owner + '.' + @TrigName
		print @selStmt
		exec (@SelStmt)
	End
	close tr
	Deallocate tr
	drop table ##sde_1_TriggerName
end
close ch
Deallocate ch
drop table ##sde_0_DatabaseName
SQL Server 2000:
-- SQL Server 2000 specific
Set @SelStmt =
Exec (@SelStmt)
declare ch cursor
for
open ch
begin
	set @SelStmt =
	from ' + @dbName + '.dbo.sysobjects so
	join ' + @dbName + '.dbo.sysobjects st -- representing the triggers table
	on (so.id = st.parent_obj) and (st.xtype = ''TR'')
	--print @SelStmt
	exec (@SelStmt)
	Declare tr cursor
	for
	open tr
	Begin
		print @selStmt
		exec (@SelStmt)
	End
	close tr
	Deallocate tr
end
close ch
Deallocate ch
Article ID:000009472
Software:
  • Legacy Products
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
