English
Error: Registration of binaries did not go through correctly!!
Error Message
The ArcIMS 9.2 Service Pack 3 configuration script <install_directory>/arcims/qs_scripts/SP3config.sh fails to complete successfully and displays the error message:
"Error: Registration of binaries did not go through correctly!!"
This only pertains to installations of ArcIMS 9.2 SP3 for ArcMap Server on Solaris or Linux.{/BOLD)
Cause
The ArcIMS 9.2 Service Pack 3 configuration script <install_directory>/arcims/qs_scripts/SP3config.sh relies on the successful startup of the Virtual Display server (Xvfb) for registration of the Service Pack 3 libraries.
If there is a Xvfb process already running or if there is lock on this process, then Xvfb fails to start and the registration of the ArcIMS 9.2 Service Pack 3 libraries fails.
Solution or Workaround
Before running the ArcIMS 9.2 SP3 configuration script <install_directory>/arcims/qs_scripts/SP3config.sh
a. Verify a Xvfb process is not running.
b. Remove any locks on Xvfb if they exist.
Follow the steps below:
1. Verify that ArcIMS is stopped, by checking if the following processes are no longer running:
> ps -ef | grep aimsserver.exe
> ps -ef | grep watchdog
> ps -ef | grep regss
> ps -ef | grep mwrpcss
If ArcIMS is running, stop ArcIMS by running the script: <install_directory>/arcims/qs_scripts/stop_arcims
2. After checking that ArcIMS is not running, verify that there is no existing Xvfb process:
> ps -ef | grep Xvfb
If Xvfb is running, kill the process after identifying the Process ID of Xvfb:
> kill -9 <pid of Xvfb>
3. Verify there are no existing locks on Xvfb by checking the following locations:
/tmp/.username-X11-unix/X7 (Solaris)
/tmp/.username-X11-pipe/X7 (Solaris)
/tmp/.X7-lock (Linux)
/tmp/.X11-unix/X7 (optional, exists on some SuSE machines)
/tmp/.X11-unix/X7= (optional, exists on some Redhat machines)
4. Remove the lock file if it exists.
The system is now ready for running the ArcIMS 9.2 SP3 configuration script.
