English
Problem: Projection files (PRJ) do not display in the Coordinate System folders
Projection files, which should be listed in the Coordinate Systems directory, do not display in the following locations:
ArcToolBox Define Projection Tool
ArcToolBox Project Tool
ArcMap > Display XY Data > Edit button > Select
ArcMap > Data Frame Properties > Coordinate System tab > Predefined folder
Cause
The check box labeled 'Coordinate Systems' located in ArcCatalog > Tools > Options > General tab, in the lower window has been unchecked.
Solution or Workaround
  1. Open ArcCatalog > Tools > Options > General tab.
  2. In the lower window on the General tab, check the box labeled 'Coordinate Systems'.
Related Information
