English
Problem: Map image is not visible when using File > Print in Firefox on Macintosh with ArcWeb Explorer
The map image is not visible when using File > Print in the Firefox Web browser with ArcWeb Explorer on a Macintosh computer.
Cause
This is a Firefox/Macintosh compatibility issue.
Solution or Workaround
Print using the ArcWeb Explorer Print Widget, or use another Macintosh Web browser such as Safari.
