ERROR
Lock <#,#,Y> not found, not deleted when attempting to stop edit operation for multi-version views
Error Message
When using the sde.version_user_ddl.edit_version procedure in Oracle, the following error message displays when attempting to stop the edit operation:
"SQL> exec sde.version_user_ddl.edit_version('DEFAULT',2);
BEGIN version_user_ddl.edit_version('DEFAULT',2); END;
ERROR at line 1:
ORA-20048: Lock <893,1528,Y> not found, not deleted.
ORA-06512: at "SDE.VERSION_USER_DDL", line 765
ORA-06512: at line 1"
Cause
If the session has previously encountered the following error when calling sde.version_user_ddl.edit_version('DEFAULT',1) multiple times, the above error message displays when stopping an edit operation:
SQL> exec version_user_ddl.edit_version('DEFAULT',1);
BEGIN version_user_ddl.edit_version('DEFAULT',1); END;
ERROR at line 1:
ORA-20176: State 1528 from version DEFAULT is not closed.
This error is expected, because the state is already open. Applications should not attempt to start multiple edit operations on the version prior to stopping the edit operation.
Solution or Workaround
After the error message is returned, the result is that the state the version references is closed, and the stop edit operation is successful. The error message is a warning indicating that the internal state lock placed on the state during the edit operation is no longer present.
The error message can be ignored.
    Article ID:000009431
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
