ERROR
The character '<' cannot be used in an attribute value
Last Published: April 26, 2020
Error Message
ArcMap returns the following error message when loading and ArcIMS image service:
Error:
"The character '<' cannot be used in an attribute value."
Cause
This is a known issue.
Solution or Workaround
Escape the angle brackets characters, < or >, using the following HTML escape characters instead: &lt; or &gt;
For example:
Code:
<RASTER_EXACT transparency="0.3" value="-32768"  color="0,255,0" label="Value &lt; 0" />
    Article ID:000009430
    Software:
    • Legacy Products
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
