HOW TO
The edit sketch is used in ArcMap when sketching new features or editing existing ones. By default, the edit sketch is a green line with green vertices. The appearance of the sketch may need to be changed to make it easier to see, such as when tracing features over a dark raster image. This article provides Visual Basic for Applications (VBA) code to change the symbols used in the edit sketch.
To store the code in all the map documents, open the Normal.mxt ThisDocument code module instead.
Code:
Private Sub ChangeSketchSymbol()
'Get a reference to the Editor extension
Dim pEditor As IEditor
Dim pID As New UID
pID = "esriEditor.Editor"
Set pEditor = Application.FindExtensionByCLSID(pID)
Dim pEditProperties As IEditProperties
Set pEditProperties = pEditor
'Declare and set up the sketch line symbol
Dim pLineSym As ILineSymbol
Dim pLineColor As IRgbColor
Set pLineSym = pEditProperties.SketchSymbol
'Set up the sketch line color. The default is Red=0, Green=128, Blue=0.
Set pLineColor = New RgbColor
pLineColor.RGB = RGB(0, 128, 0) 'Enter new RGB values to change the sketch line color
'Set up the sketch line symbol properties
Set pLineSym = New SimpleLineSymbol
With pLineSym
.Color = pLineColor
.Width = 1 'Enter a new value to change the sketch line width
End With
Set pEditProperties.SketchSymbol = pLineSym
'Declare and set up the sketch vertex symbol
Dim pVertexSym As ISimpleMarkerSymbol
Dim pVertexColor As IRgbColor
'Set up the sketch vertex color. The default is Red=0, Green=128, Blue=0.
Set pVertexColor = New RgbColor
pVertexColor.RGB = RGB(0, 128, 0) 'Enter new RGB values to change the sketch vertex color
'Set up the sketch vertex symbol properties
Set pVertexSym = New SimpleMarkerSymbol
With pVertexSym
.Color = pVertexColor
.Style = esriSMSSquare 'Enter a new style to change the sketch vertex shape.
.size = 4 'Enter a new value to change the sketch vertex size
End With
Set pEditProperties.SketchVertexSymbol = pVertexSym
End Sub
Get help from ArcGIS experts
Download the Esri Support App
